starter contacs
Old Dec 29, 2004 | 07:52 AM
calicowade's Avatar
starter contacs
I just stopped by the local starter shop in Mt Airy NC, and he has the hvy duty contacs for my starter, he stated there is nothing special to get them and they are $28 installed.I bring him the starter . he even brought one out for me to look at and its the same as Larry B's.
Old Dec 29, 2004 | 09:44 AM
infidel's Avatar
If you can get the starter off yourself you may as well replace the contacts yourself also, it will only add 5 minutes to the job. The guy at the starter shop will probably do it while you wait.
Old Dec 29, 2004 | 10:01 AM
smokeyram's Avatar
I just did my contacts a few weeks back.
Was easier than oullng the sarter on a small chevy.
If you can get your arms in some tight spaces, and have socket extensions and U-joints, couldnt be easier
Old Dec 29, 2004 | 11:05 AM
kd460's Avatar
Do the contacts yourself. After the starter is removed, it's 3 screws and your there. Besides not a bad idea to look inside and see whats up. Give the plunger (or get a new one) a cleaning as well as the area the contacts sit in and your good to go. Just make sure your contacts sit level (not cocked or crooked).
Good luck, Kevin
Old Dec 29, 2004 | 12:25 PM
calicowade's Avatar
The point was that Foster truck is not the only place to get Heavy duty contacs.The starter is also dragging so I'm going to let then rebuild the whole thing anyway and put the contacts in at the same time.
Old Dec 30, 2004 | 03:42 PM
INJECTOR JACK's Avatar
I got a kit for my old mans 98 from PDR it came with the heavy contacts as well as the plunger
Sure made a diffrence!
FMB
Nov 14, 2010 09:09 PM
12valvesmoke
Jun 12, 2009 09:46 AM
buckman361
Nov 13, 2008 09:54 AM
Paradise Racing
Jan 18, 2005 09:08 AM
MJR
Mar 16, 2003 08:26 PM
