squeak in fron only when in 4wd
Old Aug 27, 2009 | 07:48 PM
dieselman2300's Avatar
squeak in front only when in 4wd
What would cause a squeak in the front right axle when its only in 4wd? I though it was the t-case, but that has been changed from a dld to a dhd. The front and rear driveshafts are new, the fron u-joints have been changed and the hubs have been changed.
Its a squeak happens when going forward, it sounds like, squeak-squeak-squeak, if you get my drift.
The truck also has a posi-lok, and all the brakes are new, calipers, rotors and hawk pads.
Old Aug 28, 2009 | 08:06 AM
patdaly's Avatar
When you find out, let me know, mine has been doing it since I got it, figured it was a U joint. Mine comes and goes, and if you drive it for a while after taking it out of 4WD, it goes away.
Sorry I couldn't be helpful.
Old Aug 28, 2009 | 08:59 AM
I'm wondering if the front half shaft is bent slightly. It just started doing it. Last winter it was fine.
Old Aug 28, 2009 | 10:08 AM
cumminsdriver635's Avatar
Id have to put my money on a U-Joint. I had to replace my Axle Joint on the passenger side a few weeks ago because the U-Joint practically locked up on me and the truck always felt like it was in 4wd because the shaft didnt want to spin freely when you turned the wheel.
Eric
Old Aug 28, 2009 | 11:15 AM
Eric
Joints are new, and it only happens when in 4wd. The joints and shafts still spin in 2wd.
One other thing is that if I apply the brakes gently, the squeak stops until I let off the brake pedal.
Old Aug 28, 2009 | 11:37 AM
Just because they are pretty new doesent mean they cant be going out....
Its just your brakes squeaking if it stops when you hit the brakes. For some reason mine does it sometimes and when i hit the brakes it stops. Drives me crazy sometimes, but the brakes are new, so whats a person to do.
Old Aug 29, 2009 | 12:03 AM
Pull my hair out and go crazy till I find the problem.
Old Aug 29, 2009 | 05:03 AM
RPegram's Avatar
Loose lug nuts or a cracked rim can also cause a squeak you are describing. A loose axle inside of the hub is also a possibililty. It would not hurt to go back and retighten everything that was taken loose to install axle u-joints.
shep1
Aug 29, 2010 10:19 PM
CTD2001
15
Nov 28, 2009 07:54 PM
ytodd
Nov 2, 2007 09:57 AM
gman07
May 9, 2007 06:03 AM
hotdram
31
Sep 17, 2005 08:00 AM
