Spindle Nut Help
Old Sep 1, 2007 | 07:29 PM
Cam73's Avatar
Spindle Nut Help
I was going to put some new rotors on today but I've ran into a small hold up. I broke a few 1/2 drive extentions tying to get the drivers side spindle nut loose. I hit it with PB blaster 30 min. before but I think I'm going to need something more. Any tips? Thanks
Old Sep 2, 2007 | 10:51 AM
infidel's Avatar
Try some heat.
Sometimes they get galled on and you have to split the nut with a grinder or nut splitter to get it off without taking off the threads on the axle end ($$$)
If you have to resort to a 6' cheater bar chances are high that you might take the axle threads off with the nut.
Old Sep 2, 2007 | 11:17 AM
97' CTD's Avatar
Heat,Heat,Heat,Heat
Brandon
Old Sep 2, 2007 | 11:21 AM
Cam73's Avatar
Thanks guys, maybe I'll have better luck today.
Old Sep 2, 2007 | 02:27 PM
Cam73's Avatar
Well I think I took the threads on the driver side. It was going well but now I can't get it to move at all..
Old Sep 2, 2007 | 10:47 PM
Cam73's Avatar
I ended up cutting the nut with a dremel and splitting it with a chisle. I did take some threads off but I"m going to add a few washers with the new nut and I should be able to get some bite. I'll have to find some other way than a cotter pin to secure it though.
DieselDale
May 23, 2020 02:56 PM
Crimedog
Sep 1, 2008 06:49 PM
DieselDale
Apr 5, 2004 07:49 PM
apache
Feb 26, 2004 01:08 PM
wildolman
Oct 21, 2003 11:03 AM
