Speedometer correction
Any one have suggestions on how to correct my speedometer reading? I have a 97 auto and went from 3:55's to 4:10's. Do I change the gear at the back of the transfer case, re-calibrated, or both?
I installed a re-calibration box from superlift.... best part is that it is fully adjustable! It also has two settings for two different tire sizes for those of you that switch tire sizes... just flip the switch.
Mine is a 4WD. I thought as you confirmed, the signal is from the gear in the tail shaft housing on the transfer case. I have the same question as Scramblinman, how do I determine which gear to use?
seralan
Mar 2, 2006 04:20 PM
ridofpwrstroke
Mar 7, 2003 07:08 PM
