So I turned up my idle...
Old Sep 26, 2006 | 06:49 PM
Common's Avatar
And all it took was a bump of the starter to get her going...
But I let her cool down and went back out and it took a teeny bit more than a bump...
But after I shut it down and restarted it, all it took was a bump...
Should I leave it, or go maybe a hair more?
Old Sep 26, 2006 | 06:57 PM
Common's Avatar
You posted this in the wrong forum...
Old Sep 26, 2006 | 07:17 PM
Racer9's Avatar
It won't hurt to turn it up a little more. With an auto you would have to worry about clunking when putting it in drive, but with your stick, no worries.
Old Sep 26, 2006 | 07:40 PM
Common's Avatar
My idle is exactly between the last mark before the 1000 mark and 1000...
Seems to idle a little high...
Is that OK?
Why do these things need adjusted?
Old Sep 26, 2006 | 08:31 PM
lonewolf42262's Avatar
the idle adj screw is basically givin the amount of fuel needed to start, basically to low thats why you need to touch the throttle
Old Sep 26, 2006 | 10:01 PM
TxDiesel007's Avatar
Is that OK?
My truck idles at 950 rpms or so with the AC off at some points, and at 850 rpms at others.. So the higher it is the better off you are. I like it due to less vibrations on the mirrors, I would leave it at 800 or so...
PS with AC on at times its at 750-850 rpms..
Rick
Old Sep 26, 2006 | 10:17 PM
Common's Avatar
Rick
Thanks man, I really appreciate all of the help and assistance you have given me...
Dale M
Feb 10, 2009 09:43 PM
hawkeye759
Feb 4, 2005 06:26 PM
big red psd cc
Dec 29, 2004 11:38 PM
tyrod
Dec 1, 2004 07:28 PM
schu
15
May 26, 2004 01:56 PM
