Seal Guide for Crank Cover query? Which way does
Old Jan 26, 2011 | 06:18 PM
Diesel_Power_2's Avatar
Question Seal Guide for Crank Cover query? Which way does
Hi all,
I am attempting the KDP fix and am ready to install the case again. The plastic piece "starter" guide has a taper and it goes on the inside I presume as the instructions indicate, But will it then pull out and not damage the new seal?
Seems quite large to do that but it must, right? I am asking as I don't wanna screw it up.
Thanks ppl.
Old Jan 26, 2011 | 06:56 PM
cj360trider's Avatar
usually those plastic guides only go over the crank by a little bit. once the seal starts on the crank the plastic piece acts really like a shoe horn does and makes getting the seal on easy. i put mine on wo the guide. jus walked my seal around the crank carefully and ive had no issues with it
Old Jan 26, 2011 | 11:28 PM
Hi cj360trider,
Hmm this plastic starter has quite a outward taper to it as I mentioned I am thinking it will damage to seal if I tried to pull it through.
Thanks for the input will see if anyone has used it with success as without it would be difficult to start as only a few thou difference in diameter of the front yellow seal to the shaft size. I do not want to fold it back or damage it obviously.
Old Jan 26, 2011 | 11:39 PM
Tate's Avatar
Put the small end in the seal, big end on the crank, push it over. Grab the guide with pliers and pull it out. Don't try and over think this.
Old Jan 27, 2011 | 05:23 AM
Thanks for the confirmation Tate.
OK so the instructions are right . I thought pulling it through would expand the seal too much. Tomorrow I will give it a go.
Cheers.
Old Jan 27, 2011 | 01:52 PM
Hi Tate,
The seal is in now no real problems with that. I just wanted to be sure. Now the PIA is bolting the Fan back in with the shroud in too. Gotta start that one first. ...grrr..
Old Jan 27, 2011 | 07:27 PM
its easier to do that step with the fan off but its also more time consuming to remove the fan and then reinstall it
Rimcrew
Aug 19, 2012 01:04 PM
sootnsmoke
Jul 17, 2011 06:31 AM
92smokin blacky
Feb 28, 2011 02:36 PM
JDG
Jan 13, 2003 11:12 PM
TON4FUN
Jan 6, 2003 08:31 AM
