is it safe to pull fuel plate
Old Mar 30, 2011 | 03:34 PM
jared thompson's Avatar
Is it safe to pull the fuel plate all the way out? If not what is a good fuel plate for a 97 215h
Old Mar 30, 2011 | 04:42 PM
lgp9999's Avatar
Yes you can remove it completely, but you're going to need a lot of turbo to keep it cool, and a lot of clutch to go with that.
Old Mar 30, 2011 | 05:13 PM
Tate's Avatar
Depends on how the AFC is setup, along with other mods. For an unmodded AFC, you still won't get full rack travel out of it.
Old Mar 30, 2011 | 05:17 PM
All I have done is turn the star wheel 40 clicks twords the engin
Old Mar 30, 2011 | 05:38 PM
Lil Dog's Avatar
I would start by bumping the stock plate forward first with the AFC. That at least keeps you in the safe area before you need a clutch, turbo etc. About an extra 100 ponies for that .
Old Mar 30, 2011 | 05:42 PM
Ok thanks I will do that.
Old Mar 30, 2011 | 06:03 PM
What size of bolt wil I need to replace the tamper proof bolt?
Old Mar 30, 2011 | 07:41 PM
Tate's Avatar
M6x1.00mm. Get socket head cap screws, makes everything easier in there.
Old Mar 30, 2011 | 11:31 PM
Lil Dog's Avatar
X2...Get 2 for both of the slot screws.
Old Mar 31, 2011 | 09:34 AM
Thanks guys that will save me a lot of running to town when I get things apart.
Old Mar 31, 2011 | 10:00 AM
infidel's Avatar
I always replace all four bolts with allan heads.
Why use two wrenches when you can use one?
Old Mar 31, 2011 | 10:05 AM
That's a good idea makes sence to me.
Old Mar 31, 2011 | 11:32 AM
BigErksG2's Avatar
grind your stock plate to get a more steady fuel curve.
Old Mar 31, 2011 | 11:37 AM
How much would you grind it?
Old Mar 31, 2011 | 10:09 PM
BigErksG2's Avatar
I usually go perpendicular to the plate at the furthest point back of everything on it from the factory and give it a little ramp at the bottom for the last 3/8" with a small flat spot on the end of the ramp so its not a sharp edge at the very bottom. I think its called a 100 profile which is a combination of a 10 and a 0 plate, a 0 plate being straight down with no ramp.
