replacing transfer case output seal?
How difficult is it to replace the output seal in a transfer case? Can you do it from the outside with the shaft stub removed?
mines been spraying oil for awhile and I figured it would be a good time to replace it.
For rear seal, pull driveshaft out, pry out old seal, pop in the new. Toughest part (for the longer trucks) is handling the 2 piece driveshaft while removing the hanger bearing on your back if no lift is available.
KATOOM
Sep 4, 2005 07:26 PM
DEC
Sep 29, 2003 09:47 AM
