Rear brakes
Rear brakes
I recently replaced the rear shoes, cylinders, and hardware on my 94. I reinstalled just how it was before, but I am not sure that the driver's side is correct. If any of you have a photo of the rear brakes, especially the driver's side, please post it or send it to me. 94 2500. Blessings to all.
Keep Haiti in your prayers. I was supposed to fly down last Thursday, but of course I can't get a flight now. It will continue to get worse there.
No, it isn't apart. But, I am getting some binding in the back brakes. I believe that the self adjuster is on wrong, because is it backwards compared to the passengers side. But, I don't see how it can go on any other way, and that is how it was before.
I always do one side at a time so I can make sure both are the same before and after working on them.
The $30 factory service manual on cd from www.genosgargage.com has good pictures.
If i had access to air i would pull my tire off for you and snap a pic. Ill see how it goes but things between my father and I have been very bad. HE threatened to knock a hole in the block of my cummins.
If he ain't around tomorrow i will get a picture for you,
I pulled the drum off yesterday, while stooping in 2" of wet, sloppy gravel and snow, and it looks correct. Rather, looking at it, it can't go together any other way. So, in light of not having anything to reference to, I am going to switch shoes around. When I got the new ones, two were marginally thicker than the other two. So, I put the thick shoes on the front, and the thin shoes on the back. I am going to take things apart, and put the thinner shoes on the front. They are binding when I apply the brakes, and I can not think of any other reason. I greased the contact points when I put everything back, and the bar running between the two shoes is properly installed (read not binding). Any further advise, or some photos of your brakes, would be welcomed. Blessings to all.
Thanks, CMAC! That is exactly what I have been looking for. And, that is how my brakes are installed, although on mine, the thicker shoe lining is towards the front, where on yours, it is on the back. I will be changing that, so see if it makes a difference. Again, thanks!
Make sure you pay attention to the swept area of the shoes, the one with less area always goes on the front. Notice on CMAC's picture how the rear shoes lining goes almost all the way to the top?
That has bit many people.
If they're backwards on yours, that should explain the lockup scenario...
GMAC, and all you others, thanks so much for your input and help! Switching the shoes around has done the trick. I had put them on the other way under the council of a good intentioned but obviously mistaken mechanic. You live and learn every day! It drives fantastic now! The brakes worked the other way, but they grabbed, and squealed. Now, they are buttery smooth.
On to the next project.
