re head gasket
Old Jan 19, 2004 | 06:05 PM
Beerrunz's Avatar
re head gasket
I want to know if I should change head bolts with new ones or use my old one? This is the second time in three months I dont know what went wrong the first time.
Old Jan 19, 2004 | 07:39 PM
dsljunkie's Avatar
A little more info on your situation and truck would probably bring more replies, as so people can give you accurate advice .
Scott
Old Jan 19, 2004 | 10:26 PM
SmokinDodge12V's Avatar
If this is going to be the third time they will have been used I would definatly get new ones and while you have the head off I would see about an O-ring job.
Old Jan 20, 2004 | 05:47 AM
Beerrunz's Avatar
I was counting the first time from cummins would you know of a web site that sells bolts?
Old Jan 20, 2004 | 01:59 PM
dsljunkie's Avatar
Go with head studs from Haisley machine.
Scott
Old Jan 21, 2004 | 06:20 AM
turbo thom's Avatar
I don't see any profile of truck as far as power output, but like I said on the other post, torque from center front, center back. Head bolts are fine up to 400 hp. Studs aren't necessary.
..PT..
ted_pulliam
Jul 16, 2009 11:33 AM
wildchild97
Sep 25, 2007 02:44 PM
blueberry
Feb 7, 2007 05:34 PM
Conn
Dec 29, 2006 06:30 AM
MADSEN
Oct 7, 2004 09:43 PM
