Question About Reading Fault Codes
Old Sep 16, 2007 | 12:17 AM
steveh1155's Avatar
I've checked and deciphered the codes that you can get from turning the ignition switch on & off with the check engine light, but my question is - are these the same identical codes that you'll get by checking with a code scanner? Or does the scanner give additional info/details?
Old Sep 19, 2007 | 12:52 AM
dieseldemon's Avatar
Depends on the scanner the better one will tell you what each code means the cheaper one gives only the code and yes they will be the same codes you get off the ign switch.
mullishacrew
Mar 18, 2012 12:41 PM
Mallard
Mar 7, 2006 07:07 PM
cmckinney
Aug 6, 2003 03:28 PM
KC Super 80
Jun 10, 2003 12:12 AM
hvanflee
Mar 10, 2003 10:53 PM
