part numbers???
Old Mar 16, 2008 | 08:37 PM
brokenspokes181's Avatar
part numbers???
I am looking for a fuel heater ( in the pre filter ) and a water drain from the water seperator for a ' 95 12v auto 4x4. Does anyone know the part number for these, as well as the harness that plugs into it ? Fleetguard makes the heater, but apparently it is only available as a complete assembly with the pre filter housing ( at least thats what the partsman at the local truck shop says ), and I don't really want to layout $230.00 for one. I have read they are not a necessity but would like to replace it anyway, if available at a reasonable cost. Checked at NAPA for the water drain, with no luck. I haven't checked the *********** as they wanted over $200.00 for an intercooler boot. Thanks, Rick
Old Mar 17, 2008 | 10:01 AM
infidel's Avatar
On a '96 the drain is part of the WIF sensor, here you go:
http://www.genosgarage.com/prodinfo....31852-S-WIF-DG
From Cummins:
heater element upper quad ring 3834185-S
heater strainer kit 3845400-S
heater element 3907766-S
cable harness 3843722-S
Old Mar 17, 2008 | 10:49 AM
John Faughn's Avatar
At Cummins I found all the heater parts could be bought separate , but like anyplace , you may need to know more than the counter guy to get what you want .
I haven't used it , so I do not have a line , but go to the Cummins web site , you should be able to find .
I just remembered I had this .
http://www.jameskowalski.com/Dodge/Parts/index.html
Old Mar 17, 2008 | 05:00 PM
Guys, thanks for the replies. This site is absolutely the greatest! John apparently the info has been removed due to Chrysler copyright infringement. Rick
sCreamin400
Nov 2, 2008 01:46 PM
psdctd
Feb 2, 2004 06:36 PM
royB
Jul 21, 2003 09:30 AM
KatDiesel
Jun 3, 2003 12:15 AM
MR. GADGET
May 1, 2003 11:24 PM
