p7100 injection pump
Old Jun 8, 2006 | 06:06 PM
Clayten's Avatar
DTR's Toad Wrangler
I am wondering if anyone has a schematic drawing of the Bosch p7100 inline pump. I would like to view both sides, front and back.
Thanks in advance.
Old Jun 8, 2006 | 06:44 PM
infidel's Avatar
I've searched around before, it appears Bosch is very protective of their drawings, you have to be an authorized Bosch shop to gain access.
Here's about the best I've found http://www.cumminsdatabase.com/read.php?id=58
Old Jun 8, 2006 | 07:34 PM
Clayten's Avatar
DTR's Toad Wrangler
Thanks Infidel you are always the one we can count on. Unfortunately I have that one. I just want to adjust my governor arm and I want to see if it is just the two bolts on the cover that are wired together that I have to take out to get the cover off. A little trivia I us to work and live in Montana, a little town called Syndney
Old Jun 8, 2006 | 08:36 PM
Dshiftff's Avatar
those would be the 2 screws, flat head.
Old Jun 8, 2006 | 08:48 PM
Clayten's Avatar
DTR's Toad Wrangler
gottcha thanks
Old Jun 8, 2006 | 10:58 PM
Abbynormal's Avatar
I guess you have already seen this article over on Cummins Database.....
Gov arm adjustment
Old Jun 8, 2006 | 11:27 PM
Clayten's Avatar
DTR's Toad Wrangler
Gov arm adjustment
Ya thanks Abbynormal I did see it. I was always wondering why I had a surge in power after 1500 rpm. Now I just have to shrink my hands so they will fit in there and get after it.
Old Jun 10, 2006 | 06:56 PM
RedRotors's Avatar
Thanks in advance.
Do you have your Bosch pump number? I will give you the exploded diagram.. I know, i also have a 94, but i can't remember the Bosch number..
Cheers,
Marc/
Old Jun 11, 2006 | 02:45 PM
RedRotors's Avatar
Ok, i found it.. 0 402 736 841. Here's the exploded view for the pump itself and the gov. assembly..
Hope this help..
Marc/
Old Jun 11, 2006 | 03:52 PM
Clayten's Avatar
DTR's Toad Wrangler
Hope this help..
Marc/
Thanks RedRotors I was just going to send it to you really good picture.
Old Jun 11, 2006 | 03:56 PM
Clayten's Avatar
DTR's Toad Wrangler
after looking at teh numbers mine are different the drawing looks the same here are the numbers I got of the side of the pump
They where on a plate with the top haveing Mopar on it, and the numbers under it
R4761367
M070437
This must be a replacement pump or some thing, do you know what might be the difference?
Old Jun 11, 2006 | 05:32 PM
RedRotors's Avatar
R4761367
M070437
Hmm i don't know what's the signification of those numbers.. You should have a plate with the Bosch numbers or something like this " PES6P120A120RS727 " on it..
The drawings i gave you are taken from the Bosch manual, so this is exactly the pump in pieces..
Cheers,
Marc/
Old Jun 11, 2006 | 07:18 PM
infidel's Avatar
Red, do you have a copy of the number reference page that goes with the diagram?
Old Jun 11, 2006 | 07:41 PM
johnzie's Avatar
re:-injector pump
Hi All.
I'm curious as to if its possible to buy the timing pin/peg seperate...item number 34 on the diagram...( is this a white/cream plastic pin.?)...Our company bought one here in the UK..was about £30...($50}...for a piece of plastic..
Of course...someone used it and lost it....Doh !!!!..
Any reply would be appreciated..
Thanks.... Chris...
Old Jun 11, 2006 | 08:03 PM
RedRotors's Avatar
Here we go..
If you need any more Bosch ref. just ask..
Cheers,
Marc/
