Opinions.........
Old Oct 23, 2004 | 12:02 PM
Ricktye's Avatar
Opinions.........
With the arrival of the colder weather, I'm wondering about truck warm up. I know we shouldn't idle for more than about 5 minutes, but what is idle? If I boost my rpm up to about 1250 with a 'high idle' setup, then is that idle? Will it hurt to idle at that rpm for say 15 minutes to warm things up? I don't think so, but wondering what others think..........
TIA
R...
Old Oct 23, 2004 | 12:51 PM
coiler33's Avatar
Do you have a fast idle cable. I have 400k on my truck with a fast idle cable, leave it idle at 1100 for 15 minutes or more at a time if you dont have a fast idle cable your truck will develope slobber.
Old Oct 23, 2004 | 01:41 PM
infidel's Avatar
Run as long as you want at 1200 rpm.
My fast idle device is the window ice scraper wedged in-between the pedal and seat. Power seat makes it infinitely adjustable.
I also totally remove my fan from now till May for a toastier heater.
Old Oct 23, 2004 | 06:20 PM
kandgo's Avatar
That is why antisieze is good on them fan nuts HUh?? Goodluck,,Rick
Old Oct 23, 2004 | 07:40 PM
Dojman's Avatar
I regularly idle mine for five or ten minutes or sometimes a little longer in winter. I havent seen any problems other than dropped fuel mileage.
Old Oct 23, 2004 | 10:25 PM
PumpDaddy's Avatar
HIGH idle is BEST used with a straight 4" exhuast, pointed toward the drunk neighbors at 6:30 a.m. that woke me and my wife up at 2:00 a.m. and allowed to "idle" for 15-20 minutes. A "line locker" for the front brakes is also usefull when backing out of your driveway, back out, lock the valve, mash the pedal, make a bunch of smoke, release the valve and HOLD ON . They've been some what quite the last few weeks, but it could also be due to the shotgun coming out the front door with that LONG clip stuck in the bottom. 5 rounds my butt. But when the weather gets cold, I always let mine idle for atleast 10-15 minutes.
Old Oct 24, 2004 | 02:02 AM
Yamadad's Avatar
Also, if you have an automatic, shift it into neutral and set the parking brake to allow the trannie to warm up too. (Since the fluid does not circulate in Park)
Haulin_in_Dixie
Jul 7, 2023 02:13 PM
bulthisl
Mar 22, 2003 07:01 AM
richard
13
Dec 19, 2002 05:18 AM
RJMontana
Dec 16, 2002 06:31 PM
