'Normal' operating temp
You worry about nothing
Cummins says,
THE COOLING SYSTEM USED ON THE CUMMINS DIESEL ENGINE EQUIPPED VEHICLES PROVIDES THE CAPACITY AND PROTECTION OF THE HIGHER GVWR AND GCWR RATINGS AVAILABLE ON THESE VEHICLES. OWNERS SHOULD BE ADVISED OF THE NORMAL SLOWER WARM UP AND LOWER ENGINE OPERATING TEMPERATURES ASSOCIATED WITH DIESEL ENGINES.
Cummins says,
This doesn't explain the coolant temperature fluctuations I'm seeing.
If it didn't do this then when you got on a hill with a heavy load the cooling system wouldn't be adequate.
I ran an oil temp gauge for awhile, it stayed rock steady even when the coolant temp was going up and down. This indicates to me that metal of the engine is staying a pretty constant temp even though the coolant gauge is going up and down.
05 CTD2500
Nov 27, 2009 08:22 PM
Chip
Jun 18, 2005 03:09 PM
Pickle
Feb 13, 2004 10:44 AM
