No Shifting!!
Old Jan 29, 2008 | 07:51 PM
Tennessee 12v's Avatar
No Shifting!!
Ok this has been going on since I got the truck. But now it's getting worse. Most days when I first start the truck I can put it in drive and it goes rite to 3rd gear. But if cut it off and restart it then it shifts fine.
Also some times after setting for a few hours it wont want to shift out of 2nd gear usually I can let off for a few seconds and it will shift and then no more problems.
Has anyone else had this problem, dose anyone know what it is or how to fix it?
THANKS in advance.
Old Jan 29, 2008 | 08:40 PM
downlow's Avatar
Geez
Yup I got the same problem and whish I had the answer. I think its the tps if not that then the speed sensor. Mine has been fine for a few days but I still need the fix. Do a search the tps can be cleaned and you can check it for voltage to make sure it needs replacing. LMK how it goes and ill do the same
Brendan
Oct 17, 2007 11:12 AM
98 Ram 24V
Dec 24, 2005 10:19 AM
lyvwire
Mar 20, 2003 07:45 AM
Jbolt001
Dec 1, 2002 01:31 PM
