NO black smoke once it gets turbo boost- 215 pump
Old Dec 6, 2005 | 10:07 AM
DIESELRYAN3500's Avatar
O.k., Then Wy Is It Smokin So Much After 2500 Without The Wastgate Opening ??
Old Dec 6, 2005 | 10:11 AM
plow's Avatar
without the wastgate theres no way to put the fire out. Is your wastegate disconnected?
Old Dec 6, 2005 | 10:15 AM
It Will Do This With Or Without The W.g. On Or Off ( Adjustable Boost Elbow On The Afc.
Old Dec 6, 2005 | 10:22 AM
plow's Avatar
could be that your govener arm is going under your plate. You have got to have the afc tuned just right to minimize smoke. everything forward is not always best. But when you turn these pumps up and they start to defuel they are going to smoke at WOT. mine justs hazes abit at WOT and my preboost smoke will clear up in 2 to3 seconds.
Old Dec 6, 2005 | 10:29 AM
plow's Avatar
once your truck starts to defuel your not delivering as much fuel to feed that ctd. When that happens turbo slows and is not producing enough boost clear the smoke.
Old Dec 6, 2005 | 04:54 PM
I Hope The Hammer Isnt Riding Under As The Plate Is In The Middle. Last Year When I Installed It I Match It To The Hammer By Turning On The Solinoid
Old Dec 14, 2005 | 07:21 PM
12valve's Avatar
I started this tread, and i havent found any problem, why it wont flow enough fuel once the turbo spools... first 215 pump we got in with this problem...
S.O.S
any help??
Silvano
Old Dec 16, 2005 | 12:37 PM
12valve's Avatar
ok,
thanks 4 everyone who replIed my post, it wherent the delivery valves, nor the gsk, nor the plate, NO R THE INJECTORS, NOR THE afc spring, OR PLATE...
nothing but the fuel shUt off solenoid didnt come up completly...
I KNEW THAT 215 HAD TO SMOKE MORE, NOW IT DOES! AND POWER?! YES SIR!!
Old Dec 17, 2005 | 11:43 AM
plow's Avatar
are you smoking while your in the boost curve?
Old Dec 17, 2005 | 11:50 AM
12valve's Avatar
yup!!!
aint that good or what?
ok im looking toward twins now... we bought a huge turbo for the lower one, just no idea where it comes from, its in my gallery, any idea if its good 2 use it?
Old Dec 17, 2005 | 12:10 PM
plow's Avatar
with boost you shouldn't have smoke? If your smoking while in the curve might have intercooler boot off or bad turbo. I have 370's in my rig and they don't smoke with boost. Maybe I am not understanding what your describing completly. All that matters is that you got it running the way you want it to.
Old Dec 18, 2005 | 01:51 PM
12valve's Avatar
turbo is good... already treplaced a bad one with this one... and ll boots are on...
i guess it has to do with the plate, and that its a 215 pump...
our plate is a nomder 4.... no defueling at top!!
Old Dec 18, 2005 | 05:57 PM
halerazor's Avatar
my plate is completley flat and it didn't have any smoke at full throttle
Old Dec 23, 2005 | 12:10 AM
12valve's Avatar
WELL MY PLATE IS MORE THEN FLAT. ITS LIKE A NUMBER 4, WITH THE TIP ON THE BOTTEM, LIKE THE 10!
SO WHY IS MINE SMOKING AND YOURS NOT?! ALL 215 WITH A POLATE FORWARD SMOKE AT WOT, EVEN IN THE BOOST CURVE!
Old Dec 23, 2005 | 01:04 AM
halerazor's Avatar
mine didn't smoke with just a plate, just a little with 370's and the dv's really brought it on. i still think you have a boost leak somewhere. i finally realized what these guys meant that smoke don't equal power. yeah smoke is cool , but any more fueling mods before getting a bigger turbo is a waste of money. i easily have enough fuel to get over 500hp, but i dynoed this summer at 296hp using a stock turbo
