new turbo, now oil drain line wont hook up
im curious to hear what you guys have done to make your oil drain line out of the turbo work after installing a new phat shaft 62 or other aftermarket turbo, if you have any bright ideas i would love to hear them
Is it a thread issue or a lining up with the original drain hose issue? I had to get a couple of thread pieces to make mine work. The new turbo and the old oil line both had female ends I believe.
Bolt the turbine section to the manifold tight. Loosen the clamp bolts on the centersection so it can turn. You can turn it and bolt up the drain pipe tight. Then retighten the clamp bolts.
lu798welder
May 19, 2010 06:12 PM
4969joes
Mar 18, 2010 10:19 AM
pistazie
ABDTR #5
Apr 30, 2009 08:16 AM
