New Sound-Whistle to Air Pressure Hiss
Pulling my horse trailer from Sacramento to above Placerville this weekend, basically a long hill
On the way DOWN, started to hear a high pitched whistle
At first I thought maybe it was a bearing, but it was highpitched, and it got louder as I applied the pedal
At a certain spot when I pressed on the pedal, it made a scary sound
A very loud hiss, like when you are letting air out of your tires, but LOUDER
I'm thinking I have an air leak in my ?
where do I start looking?
thanks
thanks
Yes, I have gauges. My boost is usually running very low, around 0-3, hits 20 very briefly under load.
Driving without the trailer, on flat, I could only get the high pitched whistle, and that wasnt' very loud.
Thanks, I'll start at the intercooler boots and move on up. check my gauge tubing too, I guess
thanks, Jenni
thanks, Jenni
My bet is a leak in the boost gauge tubing at low pressure.
Probably at the connector at the gauge or manifold.
When the boost is up it expands and seals the leak.
Would also cause the boost to read low.
I did check my intercooler boots, the one on the drivers side attached to the intercooler the clamp was loose- well, off, really. So I tightened all of 'em down even tighter--guess I was worried I'd cut the boots but guess I'll just have to keep an eye on them.
Haven't pulled under load yet, but I'll see if thats the complete fix soon as I can.
Thanks to all!
Jenni
My egts usually run about 900 at WOT, hit almost 10K max max. Runs about 300 cruising. It is cool how you can totally control the egts with the pedal,
but I haven't needed to worry about it at all.
After tightening up the intercooler boot, driving without a load,
my boost still runs very low,so per Infidel, I'm going to check the gauge connections on either end as well. I did a cheap trick trying to use silicone hose for the boost gauge, maybe its not working
Hope thats it and not my turbo!
Maybe because I have a 5 speed, and I was traveling in 4th gear to slow down my load. When I was on flat ground, it took more pedal to get the sound.
Thanks to all!
Jenni
Thanks to all!
Jenni
Glad you did find a loose boot. Better to find it now, then on the road somewhere when it goes completely.
