New Owner
Old Mar 24, 2003 | 11:27 PM
beaner's Avatar
New Owner
Purchased a 95 TD it has a fuel plate,gauges pyro and oil,b&d tourque converter and cat back exhaust. 98% of the time runs great but once in awhile it will not start when cold I am talking not real cold but cold like 6 degrees celcious .I can crank it over no problem the solenoid is lifting I can not push it any farther up when someone is cranking it for me. I do not smell any diesel out of the exhaust then all of a suddden it will crank over and start when ever I start it it will run low rpms I will bring it up to a 1000 and hold it for awhile then it will hold 650 ish if plugged in it will start and hold 650 ish when warm it will run like a dream and no problem starting Never owned a diesel before but I love the truck any suggestions it has 114500kms on it now ???
Old Mar 25, 2003 | 06:29 AM
Smokee's Avatar
Re:New Owner
beaner:<br>Sounds as if you have a leaking rubber fuel or return line. check down in front of your fuel filter for dampness. It may be difficult to find the leak, since even a small air leak will cause the symptoms you describe.<br>george
truckroc
Introductions / New People
Jun 10, 2017 02:57 AM
92GhostRyder
Aug 11, 2010 08:31 AM
drivrswntd
Jan 31, 2006 08:22 AM
midwestdually
Mar 21, 2003 09:06 AM
AKCTD
Nov 2, 2002 05:57 PM
