new lift pump priming
Old Aug 20, 2006 | 10:01 AM
busted's Avatar
just put new liftpump and fuel heater in. what do i do to to make sure i have fuel in lines. i know there is a plunger but were do bleed the air out. thanks
Old Aug 20, 2006 | 10:54 AM
TxDiesel007's Avatar
All you have to do is make sure
that you have fuel in the fuel filter, i dont know if you went thru the side, the top, or the bottom (i went all three ways with mine) to put the pump in, But all i did was prime this truck until the button got harder to push and i made sure that it had fuel in the actual fuel filter, and when i went to start it up, i gave it some throttle till it quit running rough, and that was it...
Rick
PS more readin on changin my LP here...
https://www.dieseltruckresource.com/...d.php?t=111775
Old Aug 20, 2006 | 11:24 AM
infidel's Avatar
There is a air bleed screw on top of the outlet line from the fuel filter (the one towards the front) takes a 10mm wrench. Only needs to be unscrewed a couple of turns, not removed.
Old Aug 20, 2006 | 03:35 PM
busted's Avatar
thanks got r dun.
blackdiesel
Oct 2, 2008 07:04 PM
Roperteacher
Dec 21, 2007 08:13 PM
billv45
Jan 28, 2007 09:44 PM
robox
Oct 7, 2005 01:31 AM
Guy
Nov 21, 2002 12:09 PM
