Need help........
Old Mar 30, 2011 | 12:45 AM
440727's Avatar
Need help........
I found this 1st gen that needs a little work.
The dealer claims it just needs an injector........... Questions.......
What are common signs of a bad injector ?
Can a bad injector cause major damage ?
What should I look out for ?
Thanks guys !
Old Mar 30, 2011 | 09:26 AM
firestorm's Avatar
1: depending on how bad the injector is, it could run rough. If only slightly bad, it'll run fine but may smoke.
2: Yes, if injector is real bad, and/or been run extensively with a bad injector.
3: diesel fuel in the oil.
Hope this helps.
Old Mar 30, 2011 | 10:10 AM
infidel's Avatar
Don't think a 1st gen will add fuel to the oil like a 3rd gen does when the injector goes bad.
When an injector gets really bad it can make a loud knocking that scares the hell out of you.
Couldn't be good to run it that way.
Old Mar 30, 2011 | 10:47 AM
440727's Avatar
Thanks guys
smokin24v
Mar 18, 2008 01:21 AM
pwrtripls1
Feb 8, 2008 07:25 PM
spooling
Sep 13, 2007 10:05 PM
coupdetat
Jan 17, 2007 09:23 AM
