My 5th gear fix
I'll be the sour grape. I'll bet it vibrates back off, just like the original, in less than 50k miles. The crux of the problem is that the entire spline inside the gear is not mated to the spline of the shaft and starts to wobble after awhile. The wobbling accelerates the wear on the splines to the point that no amount of tightening can keep it from vibrating loose. Hey, you wanted to know what we think.
Local shop that repairs NV4500 noticed the same problem with the shafts & gears they were using. They switched to a different vendor. Now, they heat the gear and press it in place. No more returns.
lgp9999
good job
Excellent write up on 5th gear failure http://quad4x4.com/NV4500%205th%20Ge...0Solutions.htm
Also, traveling just under 60 in 4th gear is really revving it for those of us who have 4.10s.
Well I'm driving it and lovin' it! It's working perfectly so far!
BTW, with the Castrol Syntorq the tranny always had a bit of a hum... not a bad hum, just a hum of gears meshing together. Now that I put in Amsoil gear lube it is totally silent.
I agree with him (GAmes). I had the 5th gear problem a few years ago and after all the research, I went with a fully splined main shaft and it has been good since. When you get to the point where you have your first failure you have now worn the splines themselfs and because of this alone will accelerate the problem again because the 5th gear is able to rock on the splines. Good work and I hope I am wrong!
The thread pitch is 18 threads per inch, however when we mic'd the threaded portion it was not a normal size... somewhere around 1.67" IIRC.
He still has the CNC file to make the nuts with, however it might be kind of expensive. The two of them took a few hours to make, including having to do some hand trimming with the band saw between a couple of stages of milling. This includes chamfering the edges for better weld penetration. Then he's gotta make the wrench.
It would probably be more cost efficient just to order a couple of nuts and a wrench for them, but I needed them that day and he owed me a favor. If you're totally set at going this route (I can almost guarantee that the factory nuts are not of a material that's as hard as 4140) I can check with him.
I have a essentially the same rig as yours and I lost my fifth gear during the early Spring 2007 and have been riding around with only four gears since. Did you perform this modification because you had no fifth gear?
Thanks,
Chuck
Thanks,
Chuck
And if you've already had 5th gear failure, they say they won't even sell you the kit, because the splines have worn too much.
So are all of the other fixes still just "temporary"?
if so, about many miles?
Yes, it's very common. Take a look at the quad4x4.com link that was posted above.
Hey, per my post about the quad 4x4 link,
Did I mis read it, as I stated in my last post?
I mean, I didn't get that there was an easy fix that would help me with 185K miles, even though I haven't lost my 5th....did I miss something?
I also look at it this way, Quad is trying to sell a product too. Whats the difference between a tranny with 149k and 151k? Very little, if anything. Is a rebuild gonna hurt anything? No? Is it neccesary? Maybe, maybe not. Thats a judgement call. JMO.
