losing prime
Old Apr 3, 2006 | 03:45 PM
smokeyram's Avatar
losing prime
I havent been driving my truck over the weekends lately,
This morning, for the second monday in a row, truck fires up just fine. seems ok, I Pull out, get about a half block, and it dies.
I can turn it over, feather the pedal and get it back running, but a pain.
Also, in teh pasat , I have once or twice run it out of fuel, when that happend, It would not start without manaully priming.
Why would this occur, behaving like its got no fuel. Then a few cranks and it will fire back up.
Any Ideas? For the rest of the week it will operate fine with daily use.
The only thing so far is the sitting over the weekend.
thanks
Old Apr 3, 2006 | 07:15 PM
infidel's Avatar
First place to start is replacing the rubber fuel lines at the back of the engine. You will need a couple feet each of 5/16" and 3/8" hose and four hose clamps. Use diesel rated hose, preferably US Coast Guard approved. A kit is available here http://www.fostertruck.com/dodge/default.htm
The 5/16" return hose is in red below, the 3/8" feed hose starts right about where the red ends on the right side of the picture.
Your arms will get cut up and you will cuss.
If you want to make the system even better run new hose all the way from the engine to the tank and abandon the factory lines. This will eliminate future leaks in the metal lines and make the job very much easier. Will take about 12 feet of hose this way but best to measure first.
Old Apr 5, 2006 | 12:31 PM
arroyojim's Avatar
id/od?
are these inside or outside diameters?
thanks
Old Apr 5, 2006 | 07:17 PM
infidel's Avatar
Inside diameter (ID)
Crimedog
16
Oct 28, 2006 01:23 PM
fitzydog
Aug 27, 2006 09:41 PM
cmckinney
43
Mar 16, 2006 04:13 PM
GearHd6
Nov 4, 2005 06:51 PM
cummins2
13
Jan 21, 2005 04:56 PM
