Lift pump and Overflow valve
After doing some searching to try to figure out a ticking sound that is driving me crazy, I decided I am going to try to replace the lift pump and the overflow valve. I found a Lift pump for $130 and an overflow valve for $55 from Piers. Is this decent prices? Has anyone found better prices than these?
95 5-spd, 100 plate, 4in, 3k GSK, 300s, BHAF
If you do replace the lift pump, replace the two bolts with studs and nuts. It is all but impossible to install the pump using the bolts. Be careful removing the pump as the rod that connects the pump to the cam can fall in the block, making a small job into a huge one.
mainer
Jan 10, 2007 07:16 PM
rollsroyce1999
Jul 7, 2006 02:51 PM
