Intercooler leaks
Old Jan 23, 2006 | 01:04 PM
Baja's Avatar
Intercooler leaks
I have been checking my intercooler for leaks. I set up a 4" pipe plug tapped for a air chuck and 30psi gauge. I pushed in about 10 psi to charge the system. I did find two small leaks, now repaired, but I hear a small hissing from somewhere around the AFC. I sprayed soap, but no bubbles were seen. I am not sure if the sound is internal, or a real leak. It takes about 40-45 seconds for the system to drop to 0psi from 10psi. Is this normal? Is the system airtight, or should it drop in psi when charged? Can the AFC have a internal leak? Does a small leak in the intercooler system have a large impact on performance? My truck has ZERO power, especially in the low end.
Thanks in advance.
Old Jan 23, 2006 | 01:15 PM
DIESELRYAN3500's Avatar
1) could be your boost elbow that came with the tst plate ?
2) your intake boost line.
3) the afc has a leak underneath the diaphram.
also, spray around the intake plate ( could be the intake gasket ).
Old Jan 23, 2006 | 01:18 PM
yep....bet you your afc diaphram is shot. ANY holes through the system will show up as low bottom end.....this happend to me.
abchoppers
Jan 26, 2011 05:38 AM
mullishacrew
Oct 30, 2008 09:29 PM
stroker101
Aug 22, 2008 09:11 PM
bigragu
Mar 12, 2006 07:01 AM
plow
Jun 1, 2005 01:39 PM
