Installing Delivery valves...special tool?
Old Sep 20, 2004 | 05:08 PM
Jambbii's Avatar
Do I need a special tool to do dv's? It looks like I do but I am not sure. Anyone know where I could get some 181s?
Thanks
Old Sep 20, 2004 | 05:22 PM
Lil Mule's Avatar
Muted User
I do know you need the socket SP503, this is a snap on #, it is used to remove the DV. From there I'll have to leave it up to those who have done a few.
By the way, I'm sure snap on is not the only one who carries this socket.
Ya know, I wouldn't mind finding a set of 181's myself.
Old Sep 20, 2004 | 05:25 PM
Forrest Nearing's Avatar
Piers sells the socket. I've got one in my glove compartment
Old Sep 20, 2004 | 05:42 PM
Jambbii's Avatar
thanks guys for the info!
Old Sep 21, 2004 | 11:57 AM
CTD NUT's Avatar
Miller tools also has the DV socket. If you are getting used DV's make sure you get new sealing washers or else you may end up with a little fuel seapage from some of the DV's. The 181's will probably work just as well as 191's on a 160hp pump because even 181's are a large jump in size over the tiny 130's that are in the 160 pump. If you can find used 181's cheap, I would go for it - they will support alot of hp.
Old Sep 23, 2004 | 04:02 PM
Jambbii's Avatar
CTD NUT, yeah I have been searching for 181s and no luck , talk to piers and they have them but they are more expensive than the 191s. What is miller tools? Not sure if I know who they are .
Thanks
Old Sep 28, 2004 | 08:41 PM
boughtadodge's Avatar
I would avoid the 191's if you are towing they produce a lot of heat I tried them but they were way to hot so I traded them for 181's and they worked great.
Megaramasaur
13
Mar 9, 2007 07:48 AM
dodgeman01
Mar 13, 2003 05:30 PM
yrusoslow2
Feb 19, 2003 09:24 AM
1ST GEN.
Nov 25, 2002 10:26 PM
