How serious is the KDP issue?
Old Jan 24, 2007 | 10:16 AM
dieselfuelonly's Avatar
DTR question asker
So how serious is this KDP issue for the 12v's? I've got 142k miles on my 3500, and I don't plan on going crazy on the truck, nothing more than a big exhaust and some gauges for a while. Is the KDP something I still need to worry about?
Old Jan 24, 2007 | 10:20 AM
Txwelder's Avatar
KDP is something you definately need to check out. Look up some posts on what has happened when it falls out. Not pretty. No matter how many or how few mods you have, it will kill your truck all the same (Killer Dowel Pin).
Old Jan 24, 2007 | 10:39 AM
infidel's Avatar
Dowel pin damage probably strikes way less than 1% of 12 valves, problem is it can be very expensive. Might even require a new engine. It doesn't matter how many miles are on the truck or if is stock or not, it can still happen.
Not fixing the kdp is like saying you don't need auto insurance because you've never been in a wreck.
Fix it.
Old Jan 24, 2007 | 10:46 AM
TIMMY22's Avatar
it may never fall out.
it may fall out some day and just land in your oil pan.
it may fall out, get caught between your cam gear and just break teeth off the gear.
it may fall out, get caught between your cam gear breaking it off stopping the cam with some valves open while the pistons are still in motion.
how's your luck?
Old Jan 24, 2007 | 10:58 AM
Baja's Avatar
Do you want to spend 50$, a few hours with a few beers.... or do you want to spend a few thousand $, a week + of downtime and crying in your beer.....
You takes your chances, you pays your dues.
Old Jan 24, 2007 | 12:00 PM
1stGen545's Avatar
Its not serious at all. Unless it falls out. I had to replace my frount main seal at 278,000 so i looked while i had the cover off. The *&%^$# thing was about to fall out . Thank GOD for leaks. I put lock tight on it drove it back in took a puntch and dempeled the case around the end and made a KDP tab out of a sawzaw blade and it worked great. PRD sells the tab for about $3 if you dont want to make one. Also check all your bolts I had some that were loose. KLB ( killer loose bolt) just as bad
Old Jan 24, 2007 | 12:07 PM
Big Smoky's Avatar
I had mine fall out in my old 12v and I had to get a whole new timing case. It was expensive! The sad thing was, I had the $5 jig to put in there and just never did it!
Old Jan 24, 2007 | 12:14 PM
TheBigNasty's Avatar
I love my truck more and more everyday.
Old Jan 24, 2007 | 02:22 PM
Need95-00CTD's Avatar
Mine has already been done, still have the reciept. Can they fall out after they have been replaced? If so, how hard is it to fix it, and fix it permanently...I'm not sure how reputable this guy was that did the fix, it was the previous owner, so i never met the mechanic...
Old Jan 24, 2007 | 05:09 PM
sixguns's Avatar
Fed-Ex delivered my kit today from tst, it's getting done on Friday. As well as a few other mods thanks to DTR. I will feel ALOT better when it's done.
Old Jan 24, 2007 | 05:38 PM
woodrat's Avatar
My TST kit should be here tomorrow or the next day.
Old Jan 24, 2007 | 07:31 PM
CTDPower11's Avatar
I like this one the bestest!!!
Old Jan 24, 2007 | 07:50 PM
TIMMY22's Avatar
a little Hank Sr.
Old Jan 25, 2007 | 07:53 AM
DTR question asker
Ok so you guys have scared me into getting it fixed now . Is this the kit by TST you guys are referring to? And does it include everything I need to get it fixed? (I never trust what the web pages say ).
http://www.tstproducts.com/index.asp...PROD&ProdID=64
Old Jan 25, 2007 | 09:54 AM
woodrat's Avatar
yep, that's the kit. From others that have ordered it, it sounds like it is complete. And good downloadable instructions, too.
