How many start tries on a cold day?
Old Jan 22, 2007 | 10:03 PM
Mainemike100's Avatar
Grid heaters should be working if you have current draw with the wait to start light on, evidenced by the cab light dimming and then getting brighter when the wts light goes out. Still sounds like a fuel problem somewhere, mine starts to -25 F without being plugged in, cycle the grid heaters twice, then a little throttle and crank for 5-7 seconds and it'll start. Lots of white smoke for a few min until things warm up.
Old Jan 23, 2007 | 02:48 AM
BigDave12768's Avatar
Are you running any addatives?
Old Jan 23, 2007 | 09:40 AM
dieselfuelonly's Avatar
DTR question asker
So even if it cranks and fires after less than 1 second of starting... it may not be a problem?
So is it ok to give it throttle and starter at the same time... it will rev up a bit if I crank it and step on the throttle at the same time, I'm not going to damage my starter by that correct?
Old Jan 23, 2007 | 11:30 AM
Hayseed's Avatar
Mine does the same thing and it started it after I had 4k gov springs installed. Before that the beast would spring to life down to 25 deg. w/o waiting for the heater. Now at 30 deg. you have to crank let it hit then crank some more let it hit then crank and it will usually start. Haven't tried at a colder temp. but I'm sure it would be worse. I'm not real happy with that aspect of the 4k springs if that is what my problem is.
ccmckee's Avatar
Mine can be a real pain to start as well when it gets down to -28c or so.I always cycle the grids twice, crank it until it tries to fire and then cycle the grids again.I also keep the pedal about halfway to the floor and this usualy gets her going.My idle is at 800 in gear.
To check your grids put a meter on the terminals on the intake, at initial start up both grids should be live.If not follow the heavy wire down to the relays located on the inner fender, check for 12v on both sides of the relay.Then check for 12v on the small wires. Nothing there then there is another relay up on the firewall beside the brake booster.The samller one should be for the grids.All of these relays are ground activated by the computer so there should be 12 v on them at all times with the ground being activated by the 'puter.
Old Jan 23, 2007 | 01:29 PM
No you will not damage anything. If you read in your owners manual on cold weather starting its says give it 1/4 pedal to start. I always gave mine a little pedal to start it. Cold or warm and it fired right away. never any long cranks not matter how cold it was. Another place to look is the visor has starting instructions on it. I think that also says 1/4 pedal. The old 12v's are not computer controlled like the new ones are. But a some addatives are also nice in the winter
Old Jan 23, 2007 | 02:06 PM
Sootblower's Avatar
Mine has always started down to 0 DegFwith no plug in (although I avoid it if possible due to thick oil taking time to build pressure). I would guess it is more likely your winter "climatized" fuel in North Carolina not having enough kerosene and causing gelling (wax plugging) of fuel filter. Plug-in block heater masks the problem since there is the 12V fuel heater to keep fuel warm once started and unplugged. Try taking some sample fuel in a clear glass jar and leaving outside and see if wax precipitates out (or clouds badly)overnight?
Starting okay and then shutting down shortly after is a classic symptom of gelling. The fuel filter quickly gets plugged by wax particles and starves engine once started.
Old Jan 23, 2007 | 03:27 PM
DTR question asker
But 32*F temps surely aren't cold enough to start gelling fuel are they?
I'll try out you're jar advice though...
Can anyone answer this? (from a previous post that didn't get answered).
Old Jan 23, 2007 | 08:08 PM
steveh1155's Avatar
Only time I had a fuel gelling problem was at -8 (forgot to pour in the additive). It started sputtering for about a 1/4 mile then just quit. Had to leave it and come back later in the day when it was a few degrees warmer and then it started right up. Engage the starter first and then immediatly depress the pedal about a 1/4 - won't hurt anything.
Old Jan 23, 2007 | 08:10 PM
DTR question asker
I just wanted to make sure I didn't rip all the teeth off of my flywheel.
Old Jan 23, 2007 | 09:11 PM
Fueling around's Avatar
32° is not enought to gel fuel. If the feul heater isn't working it will make the truck harder to start. Warm fuel ignites better.
It is better on your starter to give the engine fuel and get it started then to crank and crank and crank.
Old Jan 24, 2007 | 06:51 AM
jughead's Avatar
starter gear is on a one way clutch so that when engine starts it will drive the gear only and not the starter itself.
Old Jan 26, 2007 | 09:10 PM
JOE M's Avatar
Still no luck. I'm not 100% sure what is giving power to the grid heaters, even where they are, but I have a good idea of what they are. I tried the two connections with little rubber boots on them near that big metal "support brace" (I know it has something more to do than that) with a voltmeter and they showed nothing. However its below freezing and raining (why can't it be snow?) outside, not to mention its pitch black, so I'm not positive I was doing everything right.
Anyway, I still think the grids are functioning alright because when the Wait to Start light comes on, all the cab lights dim, and when the light goes off everything brightens back up a little. I gave it a few more shots, including holding the starter for about 3 seconds and varying the throttle, but it still acted like it wanted to start, and even changed RPMs when I was holding the starter and varying the throttle but it never started and ran on its own.
Then I went to my other 12v, and it started just fine.
So, any other ideas? I know its definitly to warm for the fuel to start gelling up, and it ran just fine yesterday. I could smell a little bit of diesel fuel in the air too, is that something that could lead to an answer? Anyway, I ran another extension cord out there and plugged it in, and I'll see if she starts up tomorrow.
Any more ideas?
P.S. its the first truck in my sig, so its stock. I tried cycling the grids too.
I tought my ford was not gelling last year when I got stuck and needed a tow. The dealer was open late and found that the fuel was fine but there was ice that kept clogging the screen in fuel pump. W&$^^^%## I had just filled up an hour before and must have gotten some water in it.
Old Jan 26, 2007 | 09:51 PM
TIMMY22's Avatar
untreated fuel can gel at 10*F but usually not till 5*f or 0*F. For some reason, fuel systems seem to jell after you start moving. I don't know if its the air rushing through or the fuel that is in the filter stopping small particles of gel until it becomes completely blocked. Remember, your return fuel that starts to make it's way back to the tank is warmer and will help. I use howes in the truck and never had a problem. all my jelling experiences are with tractors or outside oil tanks for furnaces.
I started mine an hour ago, it was 0*. fired right off. not pluged in but I had it running about 4 hours before.
Old Jan 27, 2007 | 06:29 AM
2500's Avatar
been really fortunate to not need more than 1 second of cranking to start CTD. this is at 0 degree f with block heater plugged in.
same for 10 degree f starts without block heater plugged. step on throttle aprox. 1/8, then back off throttle, then blip to aprox. 1500 rpm, then idle motor to 1,100.
I've only been filling up at one of the highest volume fuel dealer in town.
don't know if it makes much difference, but insures I'm only getting freshest fuel.
