head gasket v.s. o-ringed head
i am seriously thinking about puting my o-ringed head off my 98 motor on my 95 motor. do i need a special head gasket or can i use a standard stock gasket? any thoughts? thank you
Once the head is cut, you cannot go without rings.
You need a thicker hd gasket if you cut the block not the head if you plane the head you need to sink the valves to the amount that was taken off the head. The block should also be marked what was thken off.
ScottGregory
Jan 26, 2008 10:27 PM
wallawalla
Sep 12, 2007 11:31 AM
storx
44
Sep 30, 2005 03:36 PM
