Head gasket replacement where to get it ?
Old Apr 25, 2006 | 12:21 PM
Valv's Avatar
Ok, I am ready to replace my head gasket.
What do I need and where to get it ?
Do I have to get a .10 or a .20 ?
Truck is a 1997 2500 4x4 auto "project" I recently purchased, it will get 370 injectors and a fuel plate but that's it, nothing else extra, since it will be a towing and work truck.
Old Apr 25, 2006 | 01:39 PM
MDMIKE's Avatar
I think you have to find out how much the head needs to be milled before you buy the gasket. That way you keep your compression as close to stock as possible.
Old Apr 25, 2006 | 01:50 PM
Valv's Avatar
For what I am reading there are only 2 thicknesses available, .10 and .20
The later is used where you have to lower compression to install large turbos and have more air/fuel volume
Old Apr 25, 2006 | 02:34 PM
John Faughn's Avatar
Take the head to a machine shop , have tested for cracks and warpage , if beyound spec. have surfaced , then the shop will measure head and be able to tell you witch gasget to use , then get it from Cummins .
Old Apr 25, 2006 | 02:48 PM
bgilbert's Avatar
There are three gaskets availabe, stock thickness, .010 over, .020 over, all marine type. You could just do like some and just get a .020 and hope its flat. Many have done so without any problems.
ted_pulliam
Jul 16, 2009 11:33 AM
wildchild97
Sep 25, 2007 02:44 PM
blueberry
Feb 7, 2007 05:34 PM
Conn
Dec 29, 2006 06:30 AM
MADSEN
Oct 7, 2004 09:43 PM
