Head gasket question
Old Jan 19, 2009 | 06:04 PM
polk5295's Avatar
Hey guys, no matter what anyone tells you dont believe them when they say that a stock headed 12v will take 55-60lbs all day. On about my 5 or 6th time going to full boost I popped the head gasket.
My question to the experienced out there is this: I plan to put ARP studs in this time but no O-rings. What thickness head gasket would you recommend and will just the studs be good enough for 60lbs?
Thanks in advance,
Andy
Old Jan 19, 2009 | 06:27 PM
infidel's Avatar
It's not just high boost that pops the HG, high timing will do it even more than boost.
Advancing the timing increases cylinder pressures quite a bit with every degree over stock timing.
Old Jan 19, 2009 | 06:48 PM
polk5295's Avatar
Yes sir I agree. I am only at 17 degrees or so and I have twins so I figure my drive pressure should be relatively low.
Thanks, keep um coming..
Old Jan 19, 2009 | 09:11 PM
Tate's Avatar
Thanks in advance,
Andy
Some gaskets are good for more than others, seems like luck of the draw.
If you are running high boost, a thicker gasket will help since it will lower compression. It just won't want to start as nice, and I hear torque and power are down for the same fuel/boost. But you can run more of it. For the price of 5 or 6 popped head gaskets, it would have been cheaper to get it o-ringed so its no longer an issue.
Old Jan 21, 2009 | 12:07 PM
1320's Avatar
orings are costing me 250....but Im only doing it cause its apart. I ve been at 60 psi (17 degrees and twins) for about 3 years and 40k miles. When it came apart, the head gasket was still perfect on stock head bolts , never even retorqued.
I d go to a .010 gasket with stock pistons.
Old Jan 22, 2009 | 04:41 AM
polk5295's Avatar
Great, thanks...
Old Jan 22, 2009 | 09:33 AM
kawi600's Avatar
Apparently a big factor is what temp your engine is at when you put your foot in it. If its fully warmed up supposedly its a lot safer than 5min from your driveway and 140F.
Im staying under 50 until I get orings and studs on.
Old Jan 22, 2009 | 09:41 AM
renopker's Avatar
Oring the head and use the bolts
ted_pulliam
Jul 16, 2009 11:33 AM
wildchild97
Sep 25, 2007 02:44 PM
blueberry
Feb 7, 2007 05:34 PM
Conn
Dec 29, 2006 06:30 AM
MADSEN
Oct 7, 2004 09:43 PM
