head gasket problem
Old Sep 14, 2007 | 10:40 PM
idacal's Avatar
head gasket problem
I have water pouring down the passenger side of the engine and I was trying to figure out what happened the timing is stock and I never went above 35 psi what causes these engines lose headgaskets I do have a 100 plate but I did not think that made a difference..any advice would be helpfull thanks
Old Sep 15, 2007 | 07:49 AM
JD730's Avatar
Where exactly on the pass. side? Up front or back by #5 and #6?
It seems at some point in time after x number of heat cycles or years the sealing traces on the gaskets in certain areas go and let coolant out, mine was from corrosion between the head and gasket. I had it happen back by #5 and #6 already, my brothers truck was seeping by the thermostat housing and the other 93 seeps in the same spot.
Old Sep 15, 2007 | 08:43 AM
catd69u's Avatar
You might want to check your timing. Mine had never been bothered, but it was at 23 degrees when I checked it......................................
Barry Franklin
Old Sep 15, 2007 | 09:36 AM
satburn's Avatar
Usually a head gasket fails to do one of the following:
  • Timing slipped resulting in an increase in cylinder pressure
  • Overheating
  • Improper torque on head bolts/studs
  • Installation error (head and/or block not prepped correctly)
  • Gasket flawed during manufacturing or installation
Looking at the gasket will most likely give you your answer. A lot will depend on where the failure is on the gasket.
I've bolded the area in your signature where I think the problem began though...
96 Dodge QC auto 4X4 hobby truck 100 plate slide forward, 4gsk, afc foot ground, tst afc spring mod, and gauges
ted_pulliam
Jul 16, 2009 11:33 AM
wildchild97
Sep 25, 2007 02:44 PM
blueberry
Feb 7, 2007 05:34 PM
Conn
Dec 29, 2006 06:30 AM
MADSEN
Oct 7, 2004 09:43 PM
