Head gasket identification
Old Aug 24, 2011 | 07:29 PM
JMZ's Avatar
JMZ
How do I tell if I have a standard , 10 or 20 ? I just took the head to the machine shop today. Shop owner said I need to go back with what I took out. I cant seem to see anything on the gasket that would say what thickness it is .
Old Aug 24, 2011 | 09:38 PM
cj360trider's Avatar
how many miles on truck and are you 1st 2nd 3rd owner? take a dial caliper to it and measure it if its not totally mutilated.
Old Aug 24, 2011 | 10:16 PM
JMZ's Avatar
JMZ
Second owner . 150k on it . What should the D I read ? Water was leaking out the right side around 4 - 5 . Had a short bolt with the head broke off . Pulled it out by hand.
Old Aug 25, 2011 | 06:28 AM
id wud venture to say you have the original head gasket. get a new set of head bolts to put it back together. or you cud go for some head studs... haha. if you can get ahold of original owner ask them if they ever did a head gasket. 150k id say is really good chance thats factory HG
Old Aug 25, 2011 | 07:01 AM
1-5-3-6-2-4's Avatar
The dots on the steel tab indicate what if is. No dots stock. one dot step one. Two dots is step two.
Sent from my Desire HD using Tapatalk
Old Aug 25, 2011 | 08:42 AM
JMZ's Avatar
JMZ
Is the metal tab in the corner or on the side ? I would say it is factory. Bolts look like they have never been touched.
Old Aug 26, 2011 | 10:52 AM
Tate's Avatar
The compressed height of the stock gasket is around .060", IIRC.
ted_pulliam
Jul 16, 2009 11:33 AM
wildchild97
Sep 25, 2007 02:44 PM
92redyj
Sep 1, 2007 12:48 PM
Conn
Dec 29, 2006 06:30 AM
MADSEN
Oct 7, 2004 09:43 PM
