has my timing slipped??
Old Apr 4, 2005 | 08:24 PM
Dusty Ratcliff's Avatar
I've got some symptoms & was wondering if maybe they were timing related??? they are as follows
1)too much smoke in the lower rpm's
2)terrible fuel mileage, 8-10mpg pulling 4 horse trailer
3)popping & cracking through the exhaust at a certain rpm (2300-2500 or so)
4)slight lope at idle, nothing horrible but noticeable
I thought i had my plate slid a little too far, but after sliding it back & removing my boost elbow ( dropped from 42psi tops, to around 32-34psi loaded) I still have lots of smoke, & bad mileage, & that horrible noise through the exhaust, I was hoping that maybe the timing would help all or @ least some of these problems, I will note that egt's are stable ( never over 900* post turbo loaded or empty) don't know if that's a problem with slipped timing or not?? any ideas??? thanks, Dusty
Old Apr 4, 2005 | 09:08 PM
Rare1's Avatar
Your fuel overflow valve could be worn out, a weak spring results in low fuel pressure in your injection pump. And yes, check your timing.
Old Apr 4, 2005 | 09:58 PM
BoostdCTD's Avatar
It could be the timing but it also sounds like a overflow valve, so I'd give this a shot first unless you've recently replaced it.
The OF valve is probably the single item the wears out most often on a 12 valve.
Precision Diesel Injection and Turbo Inc.
Marty Tompkins
888-734-7349
$35 + $5 shipping and handling.
Replacement takes one wrench and five minutes.
If you don't have a gauge symptoms are:
low RPM miss/instability
white smoke
hard starting
engine dies at idle
low power
fuel filter cracking
schaef_12
Jun 10, 2007 04:43 PM
mainer
Mar 20, 2007 10:51 AM
Zackb911
Aug 21, 2006 07:09 PM
gwhammy
17
Jan 27, 2005 08:02 AM
