Fuel heater relay
Old Feb 26, 2021 | 01:51 PM
stuthere's Avatar
Fuel heater relay
Hi. Does anyone know if and where the fuel heater relay can be purchased. Can't seem to find one. It's for a 97. Thanks
Old Feb 26, 2021 | 03:53 PM
texasprd's Avatar
There's nothing special about it that I know of - I believe a 30-amp normal-open (I believe) relay found at an auto parts store should work. Just to be sure, you're certain its the fuel heater relay you need, and not the relay for the fuel shutoff solenoid? They are next to each other and the FSS relay is heavier-duty.
Old Feb 26, 2021 | 11:41 PM
stuthere's Avatar
I was putting in new fuel shutoff and was replacing that relay and it was suggested that the heater relay and fuseable link should be changed as well. I guess i just assumed the heater relay was as big as the shutoff relay. But Thanks I'll check that out.
Old Feb 28, 2021 | 05:16 PM
texasprd's Avatar
Are you replacing the fusible link with a fuse or circuit breaker? Otherwise, there's really no point in replacing a fusible link - it's not like they deteriorate over time. I do agree, though, that if you ever overloaded such a circuit that it would be much more convenient to replace a fuse rather than a fusible link.
Old Feb 28, 2021 | 09:50 PM
stuthere's Avatar
Good idea. its 65 amp i believe. I'll get that done. Thanks for your help. Working good now after solenoid change. I cleaned up old one..Got it working..keep for spare maybe.
MDMIKE
Feb 28, 2008 10:07 PM
RenegadeT
Jun 24, 2007 10:04 PM
smokeum99ta
Jun 15, 2007 02:36 PM
singleturnout
Mar 5, 2006 04:26 PM
hobbyman
Feb 13, 2004 03:23 PM
