fuel filter
Can someone explain the term ( fuel filter cracking)? Thanks
That's when the filter cracks and leaks from too much pressure.
The lift pump on a 12 valve is capable of putting out over 100psi if the return fuel has no where to go like when a line is kinked or the overflow valve is stuck shut. |
Thanks Infidel,I'd heard that term several times but did not know what it ment.
