In-frame rebuild
In-frame rebuild
I know, pull the engine. Well a few years ago I did that on a auction purchased 98 12V club cab 4x4. Lots of work what with pulling everything north of the block including bumper, grill, radiator, inter-cooler, condenser and so-on and then sliding engine out the front. But obviously it's just work.
Now the wife's 200k mile 98 12v is smoking like a freight train, oil drips out the exhaust and #3 is dead, started all at once pulling a loaded horse trailer in the Arkansas Ozarks. I'm working 1500 miles away on a pipeline project so nephew inlaw (diesel mechanic) pulled #3 injector, looked in with a bore scope and saw no hole. However he's convinced there's a hole in the piston that he can't see or ring lands broke or something along those lines due to engine oil running out the exhaust. Wants to pull engine and do a proper rebuild. Me...... since the truck only pulls the occasional horse trailer (as mentioned was doing same when it started smoking like it was on fire) I don't want or need to spend that kind of money. She can use my 95. But it does need to be back on the road. So I'm considering seeing if he'll pull the head, remove the motor mounts, raise the engine, pull the pan, check the bores and probably pull #3 out the top. Repair as needed and reverse procedure, crank up and drive on.
Anyone gone this route, if so any comments or suggestions.
Thanks,
RR
Thanks,
RR
roxxx
Nov 19, 2021 03:07 PM
gts95
Aug 27, 2007 10:13 AM
95black2615
Dec 20, 2006 06:37 PM
ptgarcia
Sep 12, 2006 06:04 PM
