finding a 98 12v
Can you elaborate
Injector line over the top of the AFC housing requires extra effort to remove the breakoff screw and access plate. More scars after changing return fuel lines on '98s proves to me the engine is shoehorned in more than earlier models.
Sorry Bill, but I don't agree with the harder to work on thing...I work on these too.
They're no different, plate jobs are just as easy, the fuel filters are way easier to remove than a 94-96 with that stupid brake booster in the way. The engine bays are the exact same dimensions otherwise.
Clutch jobs are easier because the shift tower disassembles much easier.
Rubber fuel line jobs suck no matter what year it is...but might I add, 98 only has one rubber line. 98's have the updated vacuum pump check valves so they're not sucking engine oil through the dash vent controls and actuators.
And for the rear doors...
I have a 14 month old kid, and there's no way I'd have the back for climbing in and out of a Club cab between the door jam and front seat getting him in and out. Also I'm a musician too, so for gigs I'm constantly loading 50-100 lbs (or more) of odd size delicate gear in and out of the quadcab area...again there's no way I'd be able to do it with the ol' Club cab.
Sorry to say it Mike but if you work on these trucks very much and don't know the move the brake master cylinder trick for servicing the fuel filter on '94-'96 all I can say is you don't work on them very much.
Trick is so basic that even dealer "mechanics" know it, makes them the easiest to change.
I just did a quick look. Here's how to get an idea of what's out on the market right now, as far as '98 12v is concerned:
go to autotrader.com
Select Dodge in the make field and enter your ZIP
Fill out the form as desired, then under year range put 1998 to 1998
click "View more search criteria"
Choose the options you're looking for (diesel should be one of these choices)
Under keywords put "12"
The 1998s with a 12v that are within your search criteria come up!
jkarner
13
Dec 6, 2010 09:32 PM
powerrammaster
Nov 20, 2008 02:06 PM
7fa
Apr 30, 2006 07:49 PM
