Does anyone know of a good electric lift pump for a 12 v?
I put my newly second time rebuilt engine and could not get it to run. I found it would not build any fuel pressure. I removed the lift pump and found there is no lobe on the cam. I mean it is nice fresh clean cast. How could anyone put an engine together if they can't tell there is no lobe for the lift pump? Now I am having a problem finding an electric fuel pump that will consistently flow 30 psi and work with diesel. The only thing I can think of is putting an electric fuel pump off a mechanical 8.3. I think this should work because they use basically the same injection pump. The problem is it is $280.67 from cummins. For that kind of money I might as well put an aftermarket cam in my engine to get the most bang for the buck. I have found these lift pumps on ebay for $75, but I need an engine serial # from cummins to get the wiring plug so I can wire it. Any help and info would be greatly appreciated.
Who did the rebuild? If you paid somebody to do it i'd raise nine kinds of you know what and make them put the right cam in there!
