Differential Fluid: Change or Not to Change
....that is the question...wether tis noble-r to change it out if it looks a little "not so fresh" or to sucum to the slings and arrows of the parts counter guys who in their tyrany say "just top it off" "I never change that", "changing it will cause it to break"
oh Juliet, what shall I do. The humanity
Mark
Mark
Not waxing too poetic, are we?
When in doubt, change it out! I change my '06 gear oil every 15k (per owners manual). My F150 was supposed to be 'lifetime'. I installed a mag-hytec cover at 30k, and the fluid WREAKED! Nasty old oil! After that I changed it 1/yr regardless of miles, though usually had 15-20k/yr.
HTH
Tony
HTH
Tony
(may hold true for any number of things; lubricating oils, food, women..you name it!)
hmm
The parts counter guys seem to be in the minority on this one. They said it would increase the pressure and blow my seals if I went to nice clean oil after a very long time of running with old oil in my rear differential.
Mark
Mark
First you must understand there is no actual pressure(to speak of) on the seals to begin with...and even if there was(which there ain't)...the OLD oil would exert more pressure due to being 'thick and dirty' than any new and clean oil would!! Keep in mind pressures don't enter into the equation of rear diff fluid seals in the first place. Don't know about you, but I think I'd be finding another parts counter to deal with, right?
And I'd agree with the above posts of changing fluid at purchase time for sure. About the only other thing to be aware of is whether the diff is Trak-Lok(Power Lock, Sure-Grip, posi, whatever the flavor is this week...) and then you'd need to add a bottle of Jen-U-Wine Mommy Mopar friction additive to it. My usual $1.53 worth.
AJ Hartwell
Nov 4, 2006 01:54 PM
gnuesse
Sep 17, 2006 06:48 PM
coobie
Nov 29, 2004 04:26 PM
eswartz
Sep 16, 2004 06:52 AM
L. D. Bryant
Mar 22, 2004 03:14 PM
