Differences in 12v
Differences in 12v
Give me a little schooling in 12 valves. What are or are there differences in the 12 valve engines from 93 to 98?
I had a '03 HO that I sold last August and am ready to start looking for it's replacement. Figured I would try either a 1st or 2nd generation. I owned a '94 back in '94 and enjoyed the truck but just don't really remember it as there has been about 20 vehicle since then.
I know '91s (mid) back were not intercooled and would like to stay with an intercooled truck. Was it just the body change in '94 or were there engine differences?
Thanks
Thanks
As you saw Manuals > Autos in the horsepower department. The 215 Pump also has a "new" plunger design that has a notch cut into the top of the plunger instead of the surface being flat all the way across. 96-98 manuals are the ones you want, they are the "best" IMHO.
Any 2nd gen 12v is good and they're all practically the same. The stock hp ratings don't mean anything because with a couple mild mods all the trucks will run pretty much the same (not comparing trannies here). Don't pass up a good 94-96 just cause it doesn't have hydroboost brakes. Extended cab models started in 1995. There was major changes to body and engine between 1993 and 1994. All "2nd gen" 12v's are 94+ and are intercooled. A full medium-duty engine in a light duty pickup that blew all others away at the time. And still does...
Russell_d
Feb 25, 2007 09:12 AM
oldsmokey97
Dec 7, 2006 08:16 AM
Muddin_dude06
Apr 28, 2006 03:50 AM
