CV joint
Old Mar 28, 2007 | 04:24 PM
~Angry Tractor~'s Avatar
CV joint
I think I have a CV joint going bad on the front drivers side. It's clicking when I turn. That tire has been wearing out after about 2000 miles. Gone through 2 so far, on the 3rd one. Would a bad CV joint do this?
Old Mar 28, 2007 | 04:30 PM
ScottN's Avatar
You don't have CV joints on your front axle (there is a double u-joint "CV"joint in the front driveshaft, though).
How is the tire wearing... no tire should wear out in 2000 miles. I can't see a u-joint doing that, you need to figure out what is loose down there, or what is way out of alignment.
Old Mar 28, 2007 | 04:32 PM
NMCTD's Avatar
Nope. You need an alignment. The clicking is probably either the u-joint on the axle (they don't have cv's) or the untized bearing assembly.
Print this out http://dodgeram.org/tech/specs/00_steer_specs.html and take it with you to have your alingment done, ask them to set it to these specs, and aask for a print out when they are done to make sure they did it rite.
Old Mar 28, 2007 | 07:28 PM
Ironstone's Avatar
OK thanks. The tire wears out in the center then develops a flat spot. It's real odd. I have never seen a tire flat spot with out doing some serious brake lockup and I didn't lock up the brakes on either tires that wore out and they both did the same thing.
72dart
Jun 19, 2012 10:42 PM
wcbcruzer
22
Apr 30, 2008 06:58 PM
FDC
Jul 16, 2007 12:51 PM
Treangen
May 7, 2007 03:10 PM
drecu
May 16, 2003 09:18 PM
