Crnaks, and cranks, and cranks.
Twice now, I've had my all stock 207,000 mile, '96 crank for about 30-40 seconds before it fires. I'm assuming fuel leak down. Is this a common occurrence and where should I begin my search?
I went to local Cummins dealer today. I described the issue that my truck has, and that it starts with the nose down. He wondered if it could be the check valve on the return side, near the fuel filter. The FSS is around $500.00, and didn't have one in stock. Nice guy, he gave me the part number for the FSS, and a print out of the supply and return lines.
Not the FSS!
Back in May, I started a post regarding my all stock, '96 hard starting. When I went to the local Cummins dealer, they told me the FSS was on back order, and the price was up there. I told the counter man that if the truck had plenty of fuel, and I parked with the nose pointed down, it started fine. (This was suggested by one of the members here). The parts guy mentioned it could be the check valve on the return side. I was skeptical, but ordered it. I finally installed it a week ago, and it has fixed my problem. I did buy an FSS from Genos, just incase mine does go bad. If you do replace the check valve, be sure to get the two seals that go on either side of the banjo fitting. The check is located on the drivers side beside the brake booster. The line it's on tees off the line and runs between the last pair of rocker covers on the engine.
Re. the FSS, if you aren't already aware - Genos sells a smaller-diameter FSS (so the mounting bracket has to match). At least, when I got one from them a few years ago, it was the smaller-diameter version. If you plan to keep it in your truck for emergency purposes, you'll need to keep the appropriate tools to replace the bracket as well (and one of the fasteners in the Genos kit is an Allen-head bolt - the hardest-to-reach one that comes in underneath the AFC from the firewall side)
thebigrisky1
16
Oct 17, 2016 06:31 PM
Shorts
Apr 26, 2011 12:00 PM
