Copper head gskt
Old Aug 13, 2007 | 12:42 PM
DRKelly's Avatar
Copper head gskt
I am scared to death to put another factory gasket on this truck.
This will be the 3rd one.
The only mods I have made are
16* timing
fuel plate ground
4in exaust
I did get ARP studs, for this one, and did reused the orig streatch bolts the 1st 3 times. Does anyone make a solid copper gasket. ***
Old Aug 13, 2007 | 12:57 PM
SPLnut's Avatar
Have your head decked to get it flat first...Locate a .010 over marine head gasket from a cummins dealer and you should be ok to 50-55 psi tops as long as the head is torqued down good
Old Aug 13, 2007 | 01:01 PM
SPLnut's Avatar
10 over cummins part number 3283337
20 over cummins part number 3283339
I'm running 18.5* timing on a few more mods and not a problem yet...
Old Aug 13, 2007 | 04:11 PM
DRKelly's Avatar
Yea, I got the head decked on the 2nd gskt. It took 5k to make it flat. I also went to the cummins dealer and the marine gskt came back same as the truck gskt. They said they are the same now.WTH.
Old Aug 13, 2007 | 04:39 PM
SPLnut's Avatar
if you order one of the 2 numbers above and dont mention your truck you'll get what you ask for...I'm running the 3283339 20 over marine gasket my-self
Old Aug 14, 2007 | 04:50 PM
Paul Winey's Avatar
You should also check the block surface for flatness too. Lay a long straight edge lengthwise and diagonal and see if you can slide some feeler gauges under it. That may be your problem in addition to a warped head.
Clean the block/head extra careful and make sure to bottom tap the holes and clean out any old oil/antifreeze. That can squeeze out and ruin a head job. Also be careful when realigning the head that you don't gouge the new gasket. Lots of little things that can ruin a weekends work in a hurry.
Good luck. I'm running a 0.020 over with the ARP's at 140 ft/lb and 23* timing without a problem so far (knock on wood/metal/fiberglass/etc.).
Paul
wildchild97
Sep 25, 2007 12:37 AM
DRKelly
Jun 27, 2007 06:05 PM
Teddy Bear
14
Oct 9, 2006 10:58 PM
1ST GEN.
Apr 4, 2005 01:21 PM
justinp20012500
45
Mar 22, 2005 12:24 PM
