Coolant temp issues after HG install.....
Old Nov 19, 2007 | 06:20 AM
Conn's Avatar
So I got my truck back together...Drove it about 150 miles yesterday after a 2nd re-torque on the studs.
Everything seems to be fine with the exception of the coolant temp..
Driving down the road, the coolant temp needle will sit between 190° and the next white has mark towards the hot side...It will climb back down to 190° as soon as you come to a stop and sit for a minute or so.
I checked to make sure the belt was routed correctly . It's fine. And I don't believe the thermostat can be installed backwards due to the housing castings.
Do I have an air pocket? It only took about 2 gallons to fill my coolant system after I drained everything at the radiator. I've pulled it up a steep hill with it running and the cap off in an attempt for force an air pocket out, but still nothing.
The truck runs awesome and doesn't get "hot". It just stays warm riding down the road.
Please advise.
Thanks.
Conn
Old Nov 19, 2007 | 12:29 PM
Exekiel69's Avatar
If the everything was done properly then, Air pocket.
Old Nov 19, 2007 | 12:38 PM
dieseldemon's Avatar
Check the Vent hose and the jiggle pin to make sure the hose is not plugged and the jiggle pin is loose
Old Nov 19, 2007 | 01:37 PM
Conn's Avatar
Jiggle Pin, hmmmm....that's right next to the ka-nooder valve, eh?
Where is this jiggle pin that i'm looking for?
Old Nov 19, 2007 | 04:14 PM
ccmckee's Avatar
It is in the tstat.
Old Nov 19, 2007 | 06:11 PM
97' CTD's Avatar
Fire it up with radiator cap off and get up to temp let the T-stat open and run for awhile and it will burp itself out.
Brandon
Old Nov 20, 2007 | 10:50 AM
tbarbee1's Avatar
I'm with brandon if you still have trouble change the tstat or just do both
12valvedutchy
Jan 24, 2011 10:02 PM
archer39
Aug 19, 2010 07:33 PM
Mark Hodowanec
Aug 17, 2009 11:56 AM
jonesm8
Mar 4, 2009 12:39 AM
Lee Jolly
Jun 19, 2006 04:20 PM
