convertor lockup switch
Old Sep 13, 2008 | 02:38 AM
oldblues's Avatar
Question convertor lockup switch
hi
how do i install a switch to lockup my convertor in 2 nd gear as i sometimes tow up steep grades from a dead stop folowing other slow vehicals and need to get lockup to control heat in trany .
Old Sep 13, 2008 | 06:05 AM
CarlJensen's Avatar
Go here for the instructions.
http://www.tstproducts.com/installat...tructions.aspx
Old Sep 13, 2008 | 11:05 PM
oldblues's Avatar
hi
thank you !
also i thought i saw someware you could just tap into the tps wire near the tps to do it ?
if so which wires ect ?
thank you !
Old Sep 14, 2008 | 12:26 AM
gorms's Avatar
From my experience lockup in 2nd gear exclusivley is impossible without some valve body work, as it is a hydraulic restriction when the lever is in "2". It will lockup from a standstill, on a take-off, through 2nd gear with the switch, only in "drive" though.
93dieselZak
Jun 16, 2011 06:10 PM
turboman1
Oct 12, 2007 02:25 PM
budbon
14
Jul 11, 2007 02:52 PM
Idaho Guy
Feb 1, 2006 08:34 PM
Mark Thomas
Aug 18, 2004 10:12 PM
