Cat on 12v
Old Sep 21, 2007 | 10:46 AM
  #31
ajs1995's Avatar
my 95 didnt have one nore did a 94 and a 96 3 of them
Old Sep 21, 2007 | 01:45 PM
  #32
kas83's Avatar
Originally Posted by MikeR
Cats are bullet shaped, resonators have flat ends just like a muffler. So no they're not at all shaped the same way.
Infidel is correct; all 12 valves from January 1994 til the last 98 12v had cats, it did not matter if it was a cali truck or not.
I don't know what Kas83 and that part of Wisconson have going on as I have never seen non-cat stickers ever installed from the factory, but I have worked on trucks from all over the country, and they all originally had cats.
Emissions testing is different everywhere, many areas don't test at all.
Here in Washington, the urban ares only do a tailpipe test as you romp the throttle, there is no visual component inspection. But the outlying areas don't test, even though those people commute to the city. Lame!
I know in Colorado they do visual inspections.
My 97 came from Texas. I don't know what to say about it, I will get a pic of the sticker when I get home. Of the three diesels I've owned, I've never had one with a cat on it. Two were IDI Ford's though.
Old Sep 21, 2007 | 05:27 PM
  #33
Mcmopar's Avatar
All the 12 valves I have ever been around had or should have had one. My 98 had one, my dad's new 1996 had one, my 97 work truck had one.
Old Sep 21, 2007 | 06:11 PM
  #34
patdaly's Avatar
In addition to all this, my 97 FSM clearly identifies the Cat.........
Old Sep 21, 2007 | 06:41 PM
  #35
kevellis32's Avatar
I know for a fact that there was a cat on my truck
I will take a picture of mine and post it on here ina few
Old Sep 21, 2007 | 06:56 PM
  #36
dieselfuelonly's Avatar
DTR question asker
Both my '96s had them.
2500 still has it.
3500... kitty went missing .
Old Sep 21, 2007 | 09:17 PM
  #37
oldblues's Avatar
hi
my 98 has a cat .
i was considering removing it and the muffler and insalling a straight pipe .
would this help me any or just make it noisy ?
Old Sep 22, 2007 | 12:43 AM
  #38
Dr. Evil's Avatar
Originally Posted by lgp9999
Yes, the '98 12v had a cat.
Yes it DID
Old Sep 22, 2007 | 12:10 PM
  #39
infidel's Avatar
i was considering removing it and the muffler and installing a straight pipe . would this help me any or just make it noisy ?
Cats tend to start clogging around 80k, removing it helps. Muffler is your choice, many are availible that flow as well as a straight pipe without the extra noise.
Old Sep 22, 2007 | 05:41 PM
  #40
wcbcruzer's Avatar
When I removed my cat at 180k miles, it didn't seem clogged. I could still see through it and after I removed it, the exhaust fumes were way stinkier. I guess that indicates the cat was still working. I didn't notice a difference in performance either.
Old Sep 22, 2007 | 05:43 PM
  #41
wcbcruzer's Avatar
Yeah, I have always believe that all 94.5-98.5 12v's came with cats, regardless of state. I would like to see that some didn't come with them. When I drive in the city I worry that a cop might pull me over for having too loud of an exhaust then write me up for not having a cat.
Old Sep 22, 2007 | 08:17 PM
  #42
cameroneod's Avatar
My 03 didnt have one.
Old Sep 22, 2007 | 09:02 PM
  #43
kevellis32's Avatar
this is what it looks like
Old Sep 22, 2007 | 09:03 PM
  #44
kevellis32's Avatar
when you cut it off, SAVE IT, they are over a thousand dollars to buy from the factory if you ever need to put it back on to pass an e test...
Old Sep 22, 2007 | 09:09 PM
  #45
wcbcruzer's Avatar
Yeah, that's exactly how mine looks. And yes, I would have one on for piece of mind except the cheapest 5" cat I found was about $350!!
