Camshaft Question
Old Jul 22, 2009 | 03:35 PM
torqmonster's Avatar
Camshaft Question
Are the camshafts the same in a 1st gen and 2nd gen 12v truck?
Old Jul 22, 2009 | 03:46 PM
Also, anyone running an aftermarket cam in a 2nd gen 12v? What are your thoughts, comments, input, etc...
Old Jul 23, 2009 | 08:55 AM
bump...
Old Jul 24, 2009 | 09:23 AM
kawi600's Avatar
I have a hamilton street cam. If you install this on a stock motor chances are you will soon pop your head gasket. =)
It knocks a couple hundred degrees off the EGT up top and helps spool the turbo a tiny bit faster.
Its usually in the top of the rev range where these cams show their stuff.
Old Jul 24, 2009 | 04:50 PM
92roughstock's Avatar
Why/ how will you pop the head gasket on a stock truck? Wouldnt a hopepd up engine make more pressure, and be more subject to blowing the gasket?
Old Jul 25, 2009 | 10:42 AM
1workinman's Avatar
camshaft info
I think that I read on a forum that they are different. I can try to find the info if you like. Different timing events.
6spd05Dually
Jul 18, 2011 11:56 PM
.boB
Aug 6, 2009 07:03 PM
thumper 549
Jul 27, 2003 08:34 PM
1ST GEN.
Nov 7, 2002 10:39 PM
