cam cover
cam cover
hi guys, ive got a major leak between the trany and engine and thought it was the main seal. but after removing the trany i found that the seal is dry and good condition. but that there is a small disk like cover over the end of the camshaft that has fallen out and is pissing oil, have tried to reinstall it but it will not stay in place, it looks like it should snap in but does not i am at a loss to solve this problem as my factory manual does not even referance this any help would be apreciated thanks
the truck is a 98 ram 12valve 5 speed 4x4
It is an expansion plug, only can be driven in once, not sure of the diameter, but it is Dodge part number 04429687
You might want to get a couple, should fit in snugly, then you smack it dead center to expand.
I think that is the first report I have heard of that plug coming out. Sounds like that is fairly uncommon. Have you seen that plug come out before?
wish i knew why it came out
Happens on a KDP case repair where the person uses the the remove the gear method rather than pulling out the entire cam.
You can thank him........
you are right infdel, thats exactly what i did, just pulled front of motor apart and the cam gear has walked off the cam a bit, i guess i did not have it on properly so have to do it all over again, thanks again every one for your input
etn550
Apr 1, 2010 12:12 PM
Badd Dogg Guy19
17
May 27, 2005 12:43 PM
Commatoze
0
Oct 15, 2003 12:33 PM
thanks again
